vaccum lines
NEO92-TSI
84
Apr 18, 2003
the idiot that owned my car b4 me "tried" to make it faster by messing with the wastegate and bov vaccum lines. right now it is very odd, i cant even figure it out with the chiltons manual.
right now i have no wastegate solenoid, the bov has no vaccum line running from the top of the bov, instead i have a line running from the intake where the wastegate solenoid line is spose to go, and it runs to and odd piece attatched to the firewall. it is a black cylinder about the dia of a pill bottle on the bottom is a line out and line the line in comes from the intake behind the cone and the out goes back to the wastegate what the hell was he trying to do? the little black object has a knob on the top that turns side to side but does nothing when turned. i want to reset the vaccum lines to where they are spose to go
so does anybody have a diagram for the bov and wastegate vaccum lines
or know where i can get a new wastegate solenoid discount auto maybe?
For the BOV I believe it should be hooked into the Fuel Pressure vacuum line. This will enable the BOV to function as it should (opening to release pressure once the throttle body has a vacuum inside). As for the wastegate I'm unsure as I've no dealt with the stock turbos and my turbo kit utilizes an external wastegate/deltagate (although for that there is a line that runs from the turbo to the wastegate if that helps any). I can take a look in my Chilton's book and try and see what you're talking about when I get off work if that would help out.
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
