vac/boost readings
tboostndsm
Nov 23, 2003
I installed a boost/vac gauge last month and ever since then I have heard a humming sound coming from the gauge cluster and my vac/readings are inconsistent.(ex.20in,then 18in).I think I have a leak at the gauge but can anyone tell me if thats whats wrong?If so what are your readings at idle and when you press in the clutch?
THANX A MILLION
evo316g,3" o2 eliminator turboback exhaust,255lph,660's,afc,spearco fmic.....12.56 at 111mph
first of all is this a different car than the 12 sec 16g car in your post? a boost gauge at this point seems strange if so.
My car idles at about 18-20 but it also depends on the load on the engine. When you have the a/c on it will idle higher (18ish). when you push in the clutch and the car is winding down, it will be more like 30.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
