using an evo 8 maf with 450cc stock turbo 1g injectors
KianaLynn
34
4
Nov 2, 2016
Helena, Montana
Im currently doing the turbo swap for my 94 eclipse. My other half and I were planning on running his evo 8 injectors but we can only find just the three out of the four. So my question is: has anyone ran anything like this and if so, was there any problems?
Do you have a way to change the MAF, as in a tuning solution like ecmlink or a maf translator? That's technically the only proper way to do this, tho I'm sure through the years many have mixed and matched all manner of maf/injector combos.
Technically you'd run lean running 450cc DSM injectors with an Evo MAF, if my early morning math is right, and no tuning or adjustment solution.
Your question is a little vague are you suggesting making these changes with no tuning solution just a stock ECU.? If that's the case then no.
TO everyone asking do have ecmlink v3
You DO or DO NOT? based on the broken sentence, I'm guessing you do have ecmlink, so you should be able to select the MAF type for 3g/Evo style, at least I think that's one of the options.
