using an analog volt meter to check CELs
IHeartTurbo
3,448
16
Aug 15, 2003
Weld, Maine
I was told by a fellow DSMer that I can check to see what codes I am throwing by using an analog volt meter, but he wasn't sure exactly how to do it. I looked through my Haynes manual, but I didn't find anything. Does anyone know how?
I did this to find out my coolant temp sensor was bad. Simply switch the meter to beep mode and hook it up to the diagnostcal port with some little wiring clip thingies. I dont remember which pins. Its in my chiltons manual, buts my manuals not here. Wish I could help more, but yes its possible. Look through your manual again you might find a how to
I found it in there, I just didn't look in the right place haha. Thanks tho.
I just tried to do it and nothing happened. Does anyone know what the volt meter has to be set on? For options there are OHM X 1 K, DC mA 0.5, DC mA 50, DC mA 250, AC V 10, AC V 50, AC V 250, AC V 500, DC V 10, DC V 50, DC V 250, and DC V 500.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
