volt meter for wideband
grizzly
113
Mar 30, 2004
chicago, Illinois
has any body tried tapping the o2 sensor with a volt meter and using that as a wide band. if any one has please tell me if it works cause i'm about to try it. i just need to find out which wires it is i need to tap and what is the voltage i should be aiming for.
Why in hell would you do that? Just because you're tapping into the o2 with a voltmeter doesn't meant its a wideband o2... Just get a datalogger so you can read all vital stats and get a wideband o2.
like i said i need to find the voltage ranges it should be and tune for that along with a logger.
