used stroker kit?
mrpepper
54
Dec 25, 2011
layton, Utah
So im buying a 91 gsx non running for 400 and doing my first rebuild on it. I want to do a 2.3 stroker kit in it..but don't want to spend 1800 on a new one..would it be a good idea to buy a used one?
Doing a strocker build, or any build for that matter can get real expensive. Im 19 and spent over 1500 at least on parts so far. I dont see why buying a used one will hurt. But just dont cheap out. Make sure you do the research before any purchase.
I would set a power goal first, that will help determine how you spend on your build if you are budgeting.
A stroker set up consists of 100mm crank, rods (that are stock length), and stoker pistons. If you are looking to save a few dollars and you power goal will allow for it, recondition your stock 6 bolt rods and use those.
goodluck
Sorry I do actually have a power goal I didn't post it..I'm looking to get around 350-375 whp with the big 16g
So your saying if the stock rods still look good then just re-use them? How much power can they safley hold?
That is completely feasible goal. In fact that can be obtained without the stroker set up, but I understand that 2.3l set up for a street driven car.
as far as the rods:
http://www.dsmtuners.com/forums/newbie-forum/324943-can-stock-1g-pistons-hold-450whp.html
http://www.dsmtuners.com/forums/newbie-forum/371276-6-bolt-rods-boost-hp-limits.html
http://www.dsmtuners.com/forums/dyno-talk/389241-621whp-553tq-stock-block-ostar-motorsports.html
As you can see form those three links, there is not magic number they can hold, but have been proven to be able to support 375+ hp. I would not reuse the rods in the car, unless they look perfect. I would have them sent to a machine shop, many of our supporting vendors can do this, and have the rods reconditioned.
