Used S-AFC
619dsmer
41
Apr 30, 2004
san diego, California
What would be the easiest way to check if the used SAFC i purchased works?
Okay, sounds like a plan. Smartass.... anyways i just thought i would be able just hook the power cable to the batterie or something
That will tell you if the screen turns on. There is still no way to test if everything works, except for installing it on the car or plugging it into someone's car who already has the harness installed.
do the battery test to make sure it light up. Dude I hope it works but I always tell people do not buy used electronice because I bought a used afc from a guy about 3 yrs ago worked for about a month and then just died out of the blue(no pun intended).
