URGENT! Torque Convertor Question PICs
Arrow_Runner
199
Jul 17, 2005
Milford(Cincy), Ohio
I just got back with a replacement transmission and torque convertor, and I found out the torque convertor is different than my old one.
The first two pics are of the new TC. The differences I've seen so far are the raised edge past the flywheel gear? The old bolts won't go in very far, I think it's a different threading. And there are two holes near the bolt holes.
What are my options with this TC? Can I just get different bolts and use it? Will my starter work with it. Should I try my old TC? Can I use different TCs with the transmission?
Thanks!
New TC Pic 1
New TC Pic 2
Original TC
Ok, it doesn't look like my starter will work with this TC. I don't know if my old TC is any good or not, but can I use my old TC with this transmission?
Here's the numbers off the "new" transmission.
S-KM175
K422MPA1
After a little research I'm pretty sure this is the same thing as the original F4A22 transmission I pulled out. Can anyone verify this?
