Upper Strut Mounts
TooFast
47
Aug 18, 2006
Omaha, Nebraska
I have an 1998 Eagle Talon Es-i and I have recently installed a set of Tein Basic Dampers. I have also just installed my second set of front upper strut mounts. Are the stiffer springs or dampeners harder on the strut mounts. Should I get a set of Tein pillowball mounts or are my strut mounts just faulty. Has anyone else had this experiance?
the stiffer dampers will translate to more shock on the mounts. I have not heard of people having such a problem, though.
Pillowball mounts. You will feel every little impact that makes it through your tires.
I wouldnt use them, but im not you. You seem to be having issues with them, are they installed correctly? (not that you can really screw it up)
I meant the bushings keep failing. I just installed a new set and we'll see how they do.
