upgrade suggestions need expert help!!!
firefighter_637
109
Feb 16, 2005
Orem, Utah
hey im planning on getting a eco 16g turbo and i was told to upgrade my injectors what size injecotrs should i get and what other upgrades will i need when installing this turbo
I'm using 550's with my evo iii
You'll also NEED some kind of fuel controller (SAFC/e-manage/etc), a fuel pump (go with the 190 not the 255 on the evo), and a boost controller. It would be nice to have a FMIC and exhaust too.
Good luck
Kent
Good luck
Kent
That about sums it up.
Id go with 650's, DSM link, toss a turbo timer in there, id take the 255 walbro, boost controll and full 3" exhaust with o2 elim and external wastegate....thats just me.
but if money is an issue then I say 550's, S-AFC, 190 pump, manual boost controller, and just port the manifold and o2 housing. if your REALLY tight on money skip the turbo timer just make sure you do it manually.
to answer as for what you NEED is only 550's, 190 pump, an AFC and a cheap manual boost controller.
