upgrade path opinion
T Series Boost
4
Jul 31, 2010
Edmonton, AB, Canada
This is an 'is it worth it' type question.. since so many ppl have done it, I probably should too.
I've completed the upgrade path except for intercooler piping. Im still running my SMIC. Question is, should I be upgrading to a front mount? I see that the stock one is good to 400hp. I am probably in the 300 - 350hp range and don't plan on going much further (I'm sure we've all said that at one point...) Is the stock I/C a bottleneck? The turbo I have is pretty efficient at the boost and flow levels Im at so cooling isn't that big an issue for me. That, and I live live up north eh :(
opinions appreciated... oh, and the car's vital stats are up to date in my profile if that helps.
The stock SMIC will suit you for now, and be better than an FMIC due to less pressure drop. Get a hard pipe kit for it and enjoy.
definately get hard pipes for the ic of planning on keeping the side mount. they are very unreliable. persoanly i would get a fmic and be prepared for the future :)
Nice. Sounds like hard piping is the way to go.. and that I still have more to read. i.e. UICP. I had to look that up. :aha: I've already relocated the battery.
I think I'll keep the side mount for now, but based on the replies it could go either way. I was worried that it was a bottleneck. thanx
IMO, go FMIC if you have long-term high horsepower goals and are okay cutting up your car a bit. if you plan on sticking with a T25/T28-style turbo, keep the SMIC. if you find yourself heatsoaking the SMIC, you can always look at alcohol injection. likewise, if you buy used hardpipes, you can probably sell them down the line for about what you paid for them should you decide to go with a FMIC later.
you must be boosting high to get to 350 hp, and your goal is 400 on the smic. haha, smic is a restriction on anything over 300hp, unless you like engine knock. have you done any logging or some sort to see if the smic is right for you? you should go with a fmic, smaller turbo put out more heat which creates knock and will require a fmic with less restriction on higher boost to let you up to 350hp.
for better or worse, get a fmic with hard piping.
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
