Up and down idle
JoselitoMichaud
Aug 17, 2008
Mascouche, QC, Canada
Hi!
When I got my laser, there was a 4g63t with a 16g in it. The engine blew up then I had to buy a new one. after this one was installed, my idle was going up and down every time I let the gaz pedal go up. The engine got a 14b, could it be the problem or is there another thing that can cause that to happen?
''The pink circled terminal is terminal 10. Use an alligator clip wire on this terminal, clip the other end to ground.'' Does he mean I should clip it to my frame?
this BISS thing doesn't change anything... Even when I plug the aligatior clips, and ground them, the idle is still going up and down
  • Wanted 6 bolt NT water pipe
    • chrisman287
