Unusual head swap question
ningen
Aug 31, 2009
Willow Grove, Pennsylvania
I have an 02 Dodge Stratus R/T, and have been looking around for a bit but havent found the answer to my specific questions yet.
Considering the 6g72 in my car is the 24v SOHC motor, is it possible to swap the 24v DOHC heads from a N/A 6g72 onto this block?
I've read in another post that the cooling jacket ports dont quite match up, if this is the case, how far off is the alignment of the ports?
Are the ignitions and ECUs different as well?
If the head swap is possible, what parts would be required?
I'm only considering this as the start to a longer process of building this motor, and I am curious as to this being a feasible mod. The blocks are similar (if not the same)....
  • Wanted 6 bolt NT water pipe
    • chrisman287
