"Unused Connectors, O My"
2skippy
106
Mar 18, 2012
Dearborn, Michigan
Ok let me give a little backround, I have a 95 TSI AWD with a 6-bolt swap, full emissions delete, full A/C delete, and no foglights (you'll see why I mentioned this in a min). The car runs great with only a minor idle issue which I am still diagnosing, bad IACV I think. Over the past couple months since I bought the car I have been slowly going over it cleaning up things, and I have notice a number of unused connectors. I know that there are some connectors that are not used when swapping a 6-bolt into a 7-bolt harness and obviously I have empty foglight harnesses . I just wanted some help identifying these connectors to make sure nothing is unplugged that should be by mistake :hmm:. Thanks
This one is right under the radio din in the center console
This three are on the firewall directly behind the IM
This is coming off one of the main looms under the fusebox
Same one just a side view
This one is next the battery and is in the same loom as the TPS if that helps.
1st - No idea
2nd - fuel pump test connector, timing pin, not sure on 3rd. They are not hooked up to anything, just be chillin
3rd/4th - Boost control solenoid, sits next to coolant bottle, plug back in otherwise its a check engine light
5th - transmission, speed sensor firewall side
Pretty certain on that but someone correct me if wrong please
