lewishamilton
- 154
- 2
- Oct 11, 2011
Here,
Maryland
After installing both the Underhood Brass Shifter Bushings (on the Shifter Cable) and solid aluminum bushings on the shifter base plate, I'm still having two (possibly unrelated) shifting issues.
The first is a dead zone where I have still have some play and looseness especially in neutral, up and down, near the 3rd and 4th gear's gates. Also, I feel the improvements from the bushings (and love them), but 3rd and 4th don't feel as mechanical and tight when going in the gates.
The second, more annoying problem, I've had since I bought the car almost a month ago, is a stiffness across neutral. If I move the shifter to the left or right side of neutral it stays there, so I have to use effort to (hypothetically) move the shifter from 2nd to 5th or 1st to 5th if that makes sense.
I searched and found a few threads but they seemed to be dealing with looseness and play which were then addressed by the mods I've already performed (i.e. No Spring Action in Shifter - DSM Forums: Mitsubishi Eclipse, Plymouth Laser, and Eagle Talon Forum: DSMtalk.com). I think the second issue could be the shift spring itself, and the first possibly the cable link bushing, but I'm guessing and shooting in the dark. Any help would be greatly appreciated.
