5ch15m
- 0
- Jul 4, 2006
Spirit Lake,
Iowa
I've done a lot of searching on this site for problems but i cant seem to find someone with my
same situation..ive found a lot of threads with similar issues but i cant seem to pin-point my problem..anyway, my transmission will shift perfectly for atleast two months it seems before
i have to have my clutch bled..this generally fixes the problem for another couple months..
what happens is my shifting becomes very hard from a stop after driving the car for over
45 minutes or driving it hard at all..it requires a lot of force to get it into first gear but from there it will be ok with a little rougher shifting into the following gears, also reverse will grind
everytime the shifting becomes harder, from my researching ive found it could be many things..i dont think it is the pedal assembly because this problem is resolved after bleeding
the clutch..i have also had my master/slave cylinders both replaced..could it be the clutch
line? any help or advice would be much appreciated..thanks
