Unlikely tranny mount question
bcjjones
509
6
Nov 3, 2011
Austin, Texas
Recently I had to tap a bigger hole to mount the tranny on. The very front bolt close to the slave cylinder. Now, since that tranny went out, I just replaced it with another one. Without thinking, I mounted everything, bolted everything up and of course the last bolt is the one im talking about. So of course the hole on the trans is too small diameter to fit the larger bolt. Its hard to tell but is thst mounting hole part of the motor mount or the block?
Like i said, very unlikely its on the mount but I thought id ask!
Yea im talking about the mount at the very front of the car underneath and im talking about the bolt on the very front of the trans underneath by the slave if that makes sence?
Pretty much asking if that trans bolt goes into that mount bracket
Are you referring to the front tranny mount? If it is the one I'm thinking your talking about its in the transaxle. The only mount that connects to the actually engine is on the timing belt side.
2G's = 3 transmission mounts and 1 engine mount.
1G's = 1 transmission mount and 3 engine mounts.
No. It goes to and threads in an ear on the block. These are simply for reference:
http://www.dsmtuners.com/forums/cylinder-head-short-block/426906-shortblock-transmission-mounting-ear-snapped-off.html
http://www.dsmtuners.com/forums/road-course-autocross/258925-broken-engine-ear-blues.html
http://www.dsmtuners.com/forums/newbie-forum/301463-broken-engine-ear-mount-plus-fix.html
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
