tpi_roc
- 118
- 0
- Dec 26, 2002
Oregon
Not a newbie but this is the most relavant forum.
I'm getting fuel cutt (like symptoms?) at about 4,500 rpms. The car hits a rock wall and will not push through it. I need some ideas, here's what I know so far.
20psi boost leak test passes with flying colors.
new BPR6ES plugs gapped to .025 and the wires are in great shape.
wastegate is connected directly to the compressor outlet with a very short vacuum hose, boosts around 10psi.
No shaft play (Just throwing this in for fun).
The only mods on the car are a K&N with a cutt can, and full exhaust.
The MAF has the silencer and lower honeycomb removed, nothing else.
The car seems to run slightly lean, the plugs were whiter than I'd like to see.
Other than the fuel cutt the car runs excellent.
I've got ECU capacitors in the mail, they seem to have just started leaking but the car doesn't show the normal symptoms of bad caps, going to replace them as soon as they get here.
Help me brainstorm, any ideas?
