UICP Question
Yoshi
53
Jan 5, 2006
Richmond, Texas
I just got a HKS SSQV a couple of days ago from a friend for $100, and i know it requires hard piping so i was hoping to get some recomendations for some pipes. im still running the stock SMIC
THX
:dsm:
I'd recommend getting dejon's upper i/c pipes with an hks flange. They are really good quality and the price is reasonable.
but i'm not to crazy about the thought of having to re circulate the valve.. i'm planing on getting a MAFS & MAFT to vent the valve. so im looking for some pipes that i dont have to cut into to put the MAFS on
All this work, just to recirculate?
Again, the BOV does not require a new hard pipe. You can get a flange and weld it to the stock pipe.
I wouldn't think that it would be too difficult to get the Dejon pipe and cut it accordingly, the only other parts you would need would be the silicone couplers for the GM MAF assuming you have the translator.
The GM MAF is a mod for the stock MAS being overrun. Not nessicarily just to vent the BOV, it just works out this way in the "blow through" setup.
If you are concerned about the BOV "whoosh". Why not recirculate the HKS and use a metal tube instead of a rubber hose to recirculate? The translator just seems like a waste of money for your mods. (IMO)
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
