Type RS hole = leak
guitarhero14
246
Jul 2, 2005
Missoula, Montana
I have a true Greddy Type RS bov, I did a boost leak leak today and the hole at the back of the BOV leaks really bad. Is this because my BOV is not sealing? Is there anyway to fix this?
puts some teflon tape over the threads and call it a day.
the type rs is a POS. replace it. trust me i have one. its cause more compressor surge for me than is worth it for. it doesn't even sound that good.
Its not leaking from the threads there's just a lille hole in the back of it that looks like it was made that way and i was just wondering why it was there and if it's supposed to be doing that and it leaks from inside by the valve. I plan on replacing it soon. I haven't liked this bov since i bought the car with it already on it.
the only hole that should be in the back of it is the threaded adapter for the vacuum line.
oh you're talking about under the lip on the bottom part. huh, never noticed that at first... idk man.
If you disconnect the vacuum line and plug the line during your blt it should stop, if it still leaks out of the vent hole than your diaphram inside the valve is leaking, and could be a hole in the diaphram which could get bigger and then the valve may not open properly.
