greddy type rs
mikh338
163
Sep 3, 2007
niskayuna, New York
hey guys
so i have a greddy type rs that i want to recirculate. now i searched and found a cpl things but were not very helpful mostly people just arguing back and forth and getting off topic. i need the recirculation fitting and cant figure out what size i need. they have the 19mm, 29mm, 32mm and 34mm. i keep hearing that either the 29mm or the 32mm will work from different sites and sources. can anyone clarify this for me this would be a big help. thanks guys
mike
WTF Louder... LOL. just the same, just alil bit louder.
You will like it. just make shure check for leaks and you adjust it right.
They all leak at the adjuster screw. Teflon tape it or use pipe dope, or just A Tiny bit of blue locktight, on both the allen screw and the locknut.
Just to make shure mine was perfect from the start. I opened it up. cleaned out some kaka that the assmebler left in it. Polished up the shaft and bushing.
lapped them together, then lubed it up for the smoothest function.
Even polished the piston head, where it seats on the rubber seal. NOT ALOT! donot remove the anodize!, Just enough to make it slick. As from factory the finish is not exactly ...... smooth.
even went as far as to slightly lube the diaphram around the edges with a silicone based greese. To make shure it sealed.
Then I used Tiny amounts of Blue loctight on ALL screws to make shure Everything was sealed.
No more leaks and it now holds WAY more then I will ever boost to. Tobad they dont come like this from factory. (shoulda bought a HKS or Tial :cry:) when i presshure checked it. it held up to 27Psi and Barely leaked at 30+. Way more then I will take my
18G for Along time.
Pay attention to if it hits the bottom side of your hood. mine did. So I bought another set screw. Cut it to the length I needed, rounded off the end like the factory greddy screw, so it seats properly. :thumb:
DougR
My greddy type rs has been run venting (for about 1 week) and recirculating, and I promise you that it isn't louder recirculating.
