Greddy Type RS
GSTBlack95
255
6
Mar 27, 2005
Greeley, Colorado
Ok well I installed the bov, it sounds like a girl screaming, I had to plug the intake for a little bit till I get to work were I can get a new hose line, now does it anyone know why it keeps doing it? I put the spring on soft and it did it really bad, I keep putting on harder, I think thats what it needs to be to keep it from doing it.
Isn't the screaming just the valve opening up?
Yeah, when it comes straight from the factory, they have it at the softest setting, which leaks major boost and sounds whiny, or a girl screaming in your case..... but yes, it shouldnt be that hard to figure out, it has it on the intstructions as well, and I have that BOV too...... :talon:
what it was the gasket and bov were not tight like i first thought they were, after it became tight it works, now I think I have the valve to hard.
Adjust it accordingly, have your hood open and your car on, pull the throttle cable until the BOV sputters, and just see if it is too hard or soft, if it is too hard, you will have a pressure problem, like blowing off a pipe or a coupler, if it is too soft, you will have a boost leak problem, majorly!!! and it is a little problem that is a major pain in the a$$, but just troubleshoot it and figure it out for yourself, you only learn by doing.... :talon:
