Turns off outta nowhere
ITSME4G63
3,427
Feb 6, 2004
chicago, Illinois
Yeah, so thursday morning Im Driving to work, and my car turns off outta nowhere. So I pull to the side, and I crank it on again, it turns on only to die 1 second later. So I pop the hood, I look at all the hose connections, all the pipes seem to be on right, I check he oil level, and I notice that I was a little low, So I add some oil, crank the engine, and it stays on. Alright, now yesterday, when I drove to and from work it was ok. Then like around 7:30pm I start heading downtown, onto the highway, and the ####ign car turns off right on the highway, so I pull over to the shoulder with my emergency flahers and pop the hood, Nothing was loose, everything seemed fine, oil level is ok, So im like wtf? I look around the engine bay for a couple more minutes hoping to find some kind of loosened clamp or hose but nothing. I turn it on and it stayed on, I then drove home and the car has been sitting since then, GUYS CAN YOU HELP ME!?
new k/n filter back in sptember, new fuel filter, december, new ngk iridiums september.
Tested with pocket logger, balanced out the fuel trim with the afc, but when my car was standing still idling one fuel trim dropped below 50% right before the car died, that means it got super rich, Im beaing tol if I get the recirculation kit, that might fix the problem. Oh we did a run 2nd gear wot, at the end of 2nd when I let of the gas, car turned off, 0 knock though
Update, it was the ecu, it has been replaced, car runs fine, original ecu had capacitors leaking.
thanks, the ecu is from a galant vr-4, but it supposed to be the same shat so its all goo din the neighborhood, well until I got my new alarm installed and the place that was doing it forgot to hook my hks svc boost controller back up (its like one of the first evc's, it only has a knob to turn the boost up or down), I didnt notice it until nighttime because during the day you cant see it being lit up at all, so I guess im going to go to that place after work monday and see if thye know how to hook it back up.
