2G Turning over/ no start
studabaker
Supporting Member
208
Nov 1, 2008
Sacramento, California
This relay behind the steering wheel is clicking whe the key is on acc. She turns over with no starting up. Can anyone id this relay on the 420a? I thought it was ignition power but would it turn over if my key was not powered or sending power to turn over. My fuel pump in working, im pretty sure. My battery is old but i tried to put a jumper box on it... A sensor is not reading? Check engine light... i will scan it tommorrow.
I sprayed starter fluid into the intake manifold and no change. I tested for continuity on the automatic shut down relay which is clicking. The relay clicking is good finctionalty for the relay... I am not sure why it is doing that.
Maybe my cca is low. My fuel could have been old... it turned over strong... I tried it with my jumper box.
I have a clicking relay resolve. I believe its the automatic shut down relay...
Thanks for that wisdom. Researching testing for spark.
