Engine turns over no start
leecastillo
46
Oct 3, 2009
Orlando, Florida
Ok so over the holidays I went out of town and as always I disabled my car by unplugging fuel pump and ground from battery. Car ran fine before doing this no issue . When I returned pluged fuel pump back in and reconnected ground started car is idleded al little ruff the died out, low gas had been on for a couple of days so no biggie checked fuel pressure to make sure my idea was correct went and got some fuel put it in car then no start engine tunes over no start then went a got my computer started a log to insure I had coolest temps ( had a recent issue with this and replaced the broken wire) temps were fine, went to bed since it was dark next day tried again still no start so I started investigating I have fuel at rail in cylinders spark plugs smelled strong of fuel checked plugs have spark then while doing some reading I read to check the cam angle sensor and crank angle sensor checked both have good grounds both have power so now I'm lost the motor only has about 5 miles on it car ran and drove before this so now I stumped and was hoping I could get some Insite
Thanks lee
