turning a non turbo to a turbo set up,, any ideals,,
foxsdesignz
101
Jul 24, 2007
defuniak Springs, Florida
i cant go all out like i planned on, but this is what i would like to do, get a non turbo 1g engine and put my turbo stuff on it, manifold etc,,,, beside what i found out that there is no oil jet in the non turbo engines, it this true with all of the non turbo 4g63,
You know what would be good is to do a none turbo 6bolt or a 2.4 over the 2.0 non turbo and swap a turbo head on it and the 14b or t25 good size manifold and a 6bolt intake mani 60mm t body and some 450-575cc would work great...
Then you would have higher compression with a smaller turbo. then have a huge turbo and a lower engine compression... The 6bolts have ridiculously low compression...
I'm using a non turbo Hundai block on my gsx, when my 4g63 block spun a rod bearing. 20 psi on a 16g and still going strong. Just make sure you have the proper fuel set up.
