turn signal problem
dsmkid3
Jun 30, 2014
haverhill, Massachusetts
Im having a weird turn signal problem I was driving and go to turn left now my signal wont go off......this happened the next day after I installed my analog boost gauge I dont know if that has anything to do with It I know there was some wiring involved thats why help would be appreciated
I've had this same problem before. Turned out to be the switch inside the turn-signal lever. It's very simple to replace (you'll see how it works once you remove it).
I took apart the turn signal component everything seems fine there I think its the flasher really but I also think it had something to do with that boost gauge wiring it never did this before till put it in
You diagnosed the electrical connections? The turn signal switches go bad. If you look around on the threads, you'll find people keeping 1-2 spares around just in case. I think if it's old and you stress the mechanicals it ends up breaking. I just replaced mine yesterday, works just fine now.
The flasher is a different circuit. You can disconnect your turn signals and still have the flasher.
