turn signal problem
hcteks
Jul 2, 2008
Clinton, Missouri
So just a few days ago my turn signals were working just fine. Last night I went to turn them on and nothing at all. My hazard lights work but when i go to right or left signal nothing at all. Where is the fuse located for it so i can check for a bad fuse, and anything else i should check?
thanks in advance.
Ok, i checked the fuse, im guessing i needed to be looking at the one labeled turn lamp. it was a 10 amp fuse and it checked out ok, i replaced it just in case and still nothing.
well like i said, i would check to see if theirs a recall on the blinker switch so that they can replace it for free.
Only other thing i could think of is the relay, which is a little black box located right behind the CD player
i have a problem with my turn signal two nights ago i was gonit to turn left so i put the turn signal on but it has not stopped working since that , i put it to right but stills turns to left.. what can be the pro?
