turn signal and brake light wont work
Status
Not open for further replies.
river
282
Jun 9, 2004
Anchorage, Alaska
my left turning signal works on both front and rear, however my right turning signal only works up front. when i turn the lights on all of the lights illuminate, headlights, parking lights, and tail lights. but when i brake, only my left side brake light illuminates the right side stays just as if im not braking, however it is light up but the brake light does not work. in the daylight with my lights off, only my left brake light works. does anybody know what the cause of this could be or does my description suck?
bulb in backwards hmmm someone believes everything he reads. wrong bulb number i could see or not in all the way, but backwards weird i wonder who thought that one up. probably the same person who will say check your blinker fluid
i already replaced all the bulbs, plus it is impossible to put them in backwards. unless you expect your bulb to kind of just sit in there, then there is only one way to put them in i believe.
Keep in mind your tail light can still work but the BRAKE light (which are our turn signals too) won't work. Try swapping out the bulbs on the right side, even the ones that 'work'.
i'm having a very simular problem, do your hazards work on that side? mine do but turn signal doesn't. let me know if you find the problem to this, it will be helpfull for me too..
Status
