front turn signals wont work
Talon00b
138
Jul 30, 2005
London,
they wont work but the back ones do anyone know if this is a easy problem or am i gonna have to hunt down whats going on. even hazards dont work at first i thought it was the bulb but i switched balbs and still nothing
After changing the bulbs and checking the fuse and relays, the next step would to use a circuit tester and make sure you have a conection in the plug. Dont gound the wire to the car, ground the tester to the negative on the plug. You might just have dirt on the plug thats giving it a bad connection.
I would check the connection between the bulb socket and the factory harness. I had one side where the factory harness was replaced with female connectors (were old and snapped) and the other side just had a really bad connection through the stock clip. I replaced both sides with new female connectors, and now they work great.
Here is what mine look like now after I fixed them.
Of course this would really only apply if they stopped working after you fiddled with them. How ever it is worth checking now that you have been workign on them.
