Turn left clutch falls to the floor.
Dred
187
Apr 20, 2005
toronto,
Has anyone had this problem? When I make a left turn moving anything higher than about 10km/h the clutch droped to the floor w/o any resistence, when I depress and press again it's there nice and full. Is there a fix?
Not try to create a cw scare but I would first check crankshaft end play. You can check it with the engine in the car and completely together. Just go out, remove the driver splash sheild in the fenderwell, and see if you can phisically move pull/push the harmonic balancer in and out. If so, it is cw and I would consider a 6bolt swap. That will be an easy swap because it is a complete drop in and only need to replace the flywheel with the 6 bolt counter part.
get a leash cause that crank is walking away
OMG WTF I'd check for crank play...Maybe your lucky and it is something else...
Title: What is a Crankwalk?
Description: What is a "Crankwalk" or a 'walking' crankshaft? (Is it a crank with greasy hairy legs on crutches?)
A 'crankwalk' or 'walking' crankshaft, occurs when an engine has thrust bearing failure or "blown thrust". It is a common problem with Mitsubishi 2G 4G63 2.0 DOHC (Dual Over head Cam) engines, and we have the solution.
This condition occurs when the the crank suffers excessive movement (crankshaft end play) and causes the crank angle sensor reluctor plate to come into contact with the sensor.
Symptoms associated with the crankwalk:
1. Clutch sensitivity, strange disengage and engage points.
2. Ticking or strange noise from the pulley side of the engine when clutch is depressed.
3. Crank Angle Sensor errors ( check engine light )
4. Difficulty shifting
5. RPMS decreasing significantly when clutch pedal is depressed.
6. Clutch does not return or "sticks" to the floor after being depressed
When this happens the engine will stop running, or you will notice hard shifting, or low clutch pedal. You may also hear a slight ticking noise. There are several theories about crankwalk, however there is no 'rock hard' evidence that officially points out this problem. The movement can be from the crankshaft not fitting inside its bearings correctly, or oil quirters in your block clogging is kinda silly. the movement can place excessive or uneven horizontal loads on the thrust bearings, causing premature failures or crank angle sensor failure. Mitsubishi has no recall or TSB regarding this problem.
It appears that Mitsubishi built many 2G engines that have this ailment, 1G owners ( 1990 - 1994) do not generally need to worry, as there aren't as many problems with cranks in those cars. But its possible to get crankwalk in any car. Mazda Miatas, Volga 2.1L engines are a couple of the few other cars known to have issues like this from the factory.
Do I have crankwalk?
You can diagnose whether or not your car has crankwalk by one of the easiest ways, install a dial indicator on the block place the finger of the indicator on the front pully,carefully move the crank back and forth measure the amount of thrust,service limit is .011 or .26mm
What should I do to check or prevent crankwalk?
1. We recommend using a oil filter from a 1g at all times.. A larger oil filter and higher micron will provide for better filtration.
2. Pay attention to what your car is doing.. keep an eye on your oil pressure, and make sure you perform proper maintenance at the scheduled times.
3. Keep an open mind about it. Crankwalk isnt something you can control, people get it stock or modded. Theres no bearing on whether mods cause it or not.
4. one option is building a 6 bolt and swapping itin. Never build a 7 bolt or swap in a reconditioned one.
In some advanced cases, the car will die when making a left hand turn or will be difficult to start.
Here are a few things to consider
1.hardness of the crank
2.depth of hardness
3.method used to harden the crankshaft
4.bearing surface contact width
5.type of material bearing is made of
6.surface finish of the bearing and crankshaft
7.heat VS load and lubrication
Sounds like Crankwalk to me.
gsxtacy
Nice, thnx for all the info guys.
I indeed have crankwalk, but I also have a 6bolt laying around waiting to get fixed up and dropped in as soon as I get some cash flow.
Got it all from a parts car I bought for 320 canadian!
Sweet, i'll get right on that swap.
