Turbo XS RFL?
turbospd
34
Dec 19, 2005
Janesville, Wisconsin
I thought of getting the turbo xs rfl bov, though i've read that it is designed for people running 10-25 psi, is this true? Any one use it on stock boost? or know of any? and if so did it perfrom fine? (sound as well)
If you are running anything over 15 or 16 psi I would change direction. When I was 17 I ran this with very similar problems to IHeartTurbo. Also, this vents to the atmosphere. The most efficient way to do this is with a GM-maf and translator with a blow-thru set up. If you don't have this. I do not recommend this at all. You will basically be starving your car because it will not be getting an accurate air flow reading.
