Turbo water line material options - ss vs nylon
athlete3344
450
124
May 1, 2010
Tampa, Florida
Ive been doing some searching and im debating on replacing the stock water return line with a 6an line, depending on fitment issues.
From what ive gathered, if I go the braided route, teflon is the correct material. However, ive seen pics of most ss braided lines, and a handful of nylon braided lines. I plan on getting some DEI fireproof insulation to wrap around the line.
Ill likely have some nylon braided teflon line leftover from the fuel lines im running. Can I use this w/ DEI or should I use ss to be on the safe side?
Teflon isn't needed.
Both the standard SS and nylon braided hose are both exactly the same other than the outer covering. I've used both and never had issues with either. The SS is a little more forgiving close to heat sources but not impervious. With some smart routing either works perfectly fine.
  • For sale 2g 1999 Silver Faced Gauge Cluster
    1999 Silver Faced Gauge Cluster $120 + shipping & paypal fees* the cluster is a turbo/manual...
  • For sale 2g 2G Third Brake Light
    2G Third Brake Light $75 + shipping & paypal fees* 4 oem mounting bolts includedYou must be...
  • For sale 4G63 Aeromotive FPR
    Aeromotive FPR $85 + shipping & paypal feesYou must be registered to see element.You must be...
  • For sale 2g 2G Gauge Cluster Gauge Pod
    2G Gauge Cluster Gauge Pod $25 + shipping & paypal feesYou must be registered to see...
  • For sale 4G63 4G63 Spark Plug Cover ( Financial Mistake )
    4G63 Spark Plug Cover ( Financial Mistake ) $30 + shipping & paypal feesYou must be registered...
