cine135
- 0
- Feb 24, 2005
Los Angeles,
California
Hello to everyone, I'm a bit of a lurker here, I've been reading up and following the various dimensions of DSM tuning and have learned much, I currently own a Silver 1997 GS, the motor has about 120K on it, I bought the car from a dealer when it had 72K I've been gentle on it so far though I have installed:
1.) Cone air filter
2.) Stainless straight exhaust
3.)A Turbopac 1500, this unit is NOT production it was obtained from Turbodyne, in carpinteria CA
The intake and exhuast produced the predicted 10 hp gain from stock, The turbo however is another story altogether.
The turbopac is designed for engines up to 2 liters, it produces 5psi of boost @ 45,000 rpm
The turbopac 1500 has no oil lines as it utilizes bearings.
The instant on effect is great since I can control when the turbo works eliminating turbo lag.
I installed the the comressor unit and all switches correctly, I did NOT modify the ECU or fuel pump, fuel injectors or any other components in the car.
When installing a 5 psi turbo, is there any fuel system modification or other (excluding the turbo tubing and manifolds) modification required?
Sometimes when I actuate the unit @ 1500 rpm the engine sounds like it is struggling to rev, this never happens @ 2500 rpm and above, can too much air @ a low rpm impede essential engine functions?
After a spirited run of say 10 miles, the fuel guage shows 1/4 tank less fuel!!!
All other problems aside, when taking a 420a from non turbo to turbo, a 5 psi setup at that,
The fuel economy doesn't go from 22mpg to 3mpg!!!
What is going on here? I don't belive that my stock fuel pump is emptying out 1/4 tank of gas in 10 minutes.
10miles/3.25 gallons= 3.07mpg
Does anybody have a clue, is the fuel guage giving faulty readings?
The turbo system draws on the order of 80 amps for a 10 second duty cycle, of course the duty cycle resets everytime I press in the accelerator pedal effectively making the duty cycle as long as I want providing I either shift or pump the gas pedal.
I can see the gauges and headlights get slightly dim when the system comes on, can this cause the fuel gauge the give a faulty reading?
1.) Cone air filter
