Turbo timer shut off with key in ign.
davidgoss
Nov 9, 2004
casper, Wyoming
i have had my greddy turbo timer in for sometime and it has never worked right. i have the wriring harness to put it all in and the car will run when the key is in the acc position but when i take the key out the car shuts off.. what seems to be the problem? thanks david
The turbo timer is NOT powering one of the vehicles IGNITION wires or an ACC. wire. Check and make sure all of the ignition wires are getting powered at the Ignition switch. This should solve your problem... If you have a test light, hop under the dash and make sure the timer is throwing power to the neccesary wires to keep the car running.
The IGNITION wire is: BLACK/WHITE
The ACC wire is: BLUE/BLACK
im not sure what wires your talking about just. i will go take a look today. but shouldnt the wiring harness that goes between the ignition switch and the plug in take care of all that? or is there another wire that i forgot to hook up?
Make sure you wired the ground right. Mine is wired through the parking brake ground, so the car only keeps running if the parking brake is applied when I remove the key.
What 2 wires on teh column harness do ig 1 and ig 2 go to? I still can't get mine to operate properly? But i did get it w/o harness, just cut wires.
