turbo timer cuttin off
bigroy_80
55
Dec 11, 2003
Front Royal, Virginia
ok well ive got an hks turbo timer and just yesterday it worked fine cut the car off and it would count down. well i have 2 gauges , a/f and boost. neither of the electrical was connected because it had been knocked undone. well i hook up the a/f and boost gauge today and now when i cut the car off the turbo timer cuts off along with it. i have no idea what to do, i dont know if theres any correlation between 1 or both of the gauges being hooked up now or if its something else. please help
The HKS timer will cut off if you have the ebrake down (assuming you installed that feature). It's possible that you knocked that wire loose. I also found that sometimes when I turn my car off by going one click of the key at a time, instead of one big turn, it will cut off the timer. Your A/F gauge and your timer should in NO WAY be related to each other. I think your best bet is to check that ebrake safety wire and make sure that didn't get knocked loose.
  • Wanted 6 bolt NT water pipe
    • chrisman287
