2g_TalonTSI
- 0
- Feb 22, 2010
Denver,
Colorado
Ok i just put in a rebuilt 16g turbo on my car that i built myself and had a machine shop make the bushings (bearings). when i got it back it had very minimal shaft play(back and forth not in and out). i put it in and there are no leaks. but my problem is that it howls pretty loud at about 1lb of boost and i only get a max of 8lbs of boost as to where my stock turbo got 13lbs but it takes me till about 4k rpms before i hit 5lbs of boost. The howling gets worse the more boost i get and the wastegate is not opening very much which makes me think it has a 15lb spring in it. so why does it take so long to spool, why is it howling, and why is it only creating 8lbs of boost???? my friend told me its the bearings they were not made right...could that be the problem?
