miguelmcv
Supporting Member
- 2,718
- 261
- May 3, 2009
Fresno,
California
Hey guys, is it possible the turbo to leak oil from the union where the round collar is, I don't know what is it called but here is a pic of the piece.
I have my balanced shaft removed but the highest that it can get is 85 and 95psi of oil pressure, I don't know if it is leaking from the turbo, I checked all around the turbo and nothing even from the return oil line, I removed the collar and didn't find anything, it had a little bit of oil on the inside of the collar but nothing on the turbo.
I just wanted to know if it can leak from the turbo where the hot side meats.
The only explanation that I can think is that it is leaking from inside of the turbo and leaking to the way out where the hot side meats and goes down to the collar so that's the oily way the outside of the turbo don't get wet of oil.
I was planing to bring the turbo out and check, but before to do that just wandering what you guys think. Any advice?.
