Turbo exhaust housing compatability
bluegs03
492
3
Apr 4, 2007
Dallas, Texas
Its a complicated title but a simple question. Will a bullseye mitsu flange turbine exhaust housing that fits a t3/t4 garrett turbo with the stage 5 p-trim turbine wheel, fit into a holset HX-35? If not is it worthwhile to machine it to accept the hx-35? about how much does this run you?
Will not fit, probably isn't worthwhile machining if it could fit.
Honestly, the DSM bolt-on housings that Bullseye makes are less expensive than a new MHI turbine housing. There's no reason to be cheap- just bone up and buy the one that fits your turbo to keep things simple. There's probably someone out there willing to buy your P-trim housing for a reasonable price that will make you both happy.
ok thank you for your advice a little birdy told me that turbo trader might have some bolt on housings for sale tomorrow! :shhh: I guess im trying to cut a few too many corners LOL!
Someone on the forum had a garrett housing machined for a holset. The turbo shop where i live charges about $65 to machine a housing for a wheel they have the specs for. I waited over a month of next weeks from bullseye before i bought a used housing.
i actually just tried this a few minutes ago. the holset turbine wheel actually fit but it looks like the p-trim exhaust housing is actually bigger than the holset turbine wheel. i have miltary duty this weekend but i can post a pic on monday
