Turbo engine problems
90 Talon AWD
148
Aug 27, 2008
jonesville, North Carolina
The other day i was going down the road being hard on my car dies and it makes a buzzing niose and stays dead. tore in to it broken balence shaft belt. so i replace the timing belt and balence shaft belt. still will not start no spark and no compression and boost gauge will not come on will i turn the key on. so i dont know what is wrong. Thanks for the help.
i just put a brand new ecu it 1 mouth ago do you guys think i might have bent valves too.
check the crank position sensor. The same thing happened to me a few days ago. When I inspected the area arond the balance belt, I noticed a piece of it broke the sensor. Make the sure the metal plate behind the crank pulley is not bent either.
i know the plate is not bent where will the crank postion sensor be located at so if i had bent valves i could hear them when i try to crank it.
yepe that is what it does. when it turns over it sounds wierd so i guess i have bent valves. and i also did a compression test on all 4 and there was no compression. si i have bent valves.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
