turbo combination and kit
luiginocrazy
Jul 5, 2012
fredericksburg, Virginia
ok first off:
need sum advice about dis turbo i got....its a garret/turbonetics turbo
da turbine section is garret nd da compressor section is turbonetics...has minimal shaft play
but i jus wanted to kno if yall think its a good combo to use???
any suggestions or advice for it
nd second:
### should i do for da rest of da turbo parts...should i go pull dem off a gsx or gst or should i buy dem from sumwhere?
i was told to pull em off gsx or gst, but will everythin bolt up without having to do major changes?
Ok, first off if you want a proper response please use proper grammer. "dis turbo is wack yall" is not.
Secondly what are you trying to do exactly? Turbo seems fine, but what do you want to do with it? What car do you have? The questions you asked are all dependant on the ones I just asked.
Spellcheck is free for all to use. Please do so in the future.
We can't tell you if that turbo is a good combination or not because you haven't given us any specs on turbine/compressor inducer/exducer sizes.
Considering you have a Chrysler 420a motor in your 99 Eclipse, nothing from a Mitsubishi 4g63 engine GST or GSX will "bolt up" without modification. Your best bet is to buy a dedicated install kit, preferably new, from a reputable vendor.
In your next thread, spell check before you post.
