Turbo cams in nonturbo 90 gs
4G63GS
Mar 23, 2005
suffolk, Virginia
is this all i need? I plan on buying a rebuilt turbo head with turbo cams i know everyhting is the same but the intake cam. im going to install 450cc injectors also and i know my cpu wont push but 400 so ima stick a fwd turbo ecu in also is the a good idea?? i plan on swapping my na block with a turbo block soon so any advice on the turbo head with 450cc injectors?? thanks guys
i've hurd that n/t cam's are better in the turbo car's for some reason.... better knife edge or somthing, i'm guessing it's the same vise-versa, in my opinion i think it would be better for your set up.. go for it :thumb: :dsm:
No, not exactly. One of the non turbo cams (automatic) is better and one of the turbo 5 speed cams is better.
Start reading at post #8
http://www.dsmtuners.com/forums/showthread.php?t=17110&highlight=cam+differences
Some day that info needs to be extracted so you people won't keep asking. This should give you more power and yet keep a good idle and higher RPM without buying some racing cams.
Cheers,
GTM
Boosted90GST said:
awsome! thanks for the re-direction GTM :thumb:
You are welcome. There may be hope that it will get reduced and improved upon to something more meaningful.
Cheers,
GTM
    • george bromwell
    • pma1123
    • Sdcryan1
