Tuning Software help!
Byrd
455
4
Sep 28, 2004
Charlotte, North Carolina
I have just started reading about burning my own chips. I'm going to purchase the Ostrich and use TunerPro RT to do all my tuning. I've searched and i havnt found a whole lot of info about these two. How would i go about getting Stutterbox and NLTS would i have to do some extra wiring? (and what would that be?) and does anybody have any usefull info on how to use TunerPro because i looked at the free one and it looks extensive to the point where its out of my league. Any info would help! thanks again :)
Ok so i found the .bin file for the stutterbox and NLTS. And the files that came with that make tuning alot easier so I'm good in that aspect. My question is now, Do i need an Eprom ECU in order to use the Osterich Emulater?
If you decide to run all the time with the emulator installed there's lots that can be done above and beyond what's been done in typical mods to chips. The limiting factor right now on 1G ECU is available R/W memory. One example of what can be done is the on the fly tuning in the Speed/Density project. It's the use of the Ostrich that makes that possible. With the right coding you can do everything a DSMlink does.
Steve
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
