tuning question
mattspyder
1,046
Nov 2, 2004
del taco, Wisconsin
alright, i have 650 injectors, so tuning with a pocketlogger, and safc II, should i tune it to ZERO or should i go alittle above zero. because of the flow rate from the bigger injectors?? it was just something that came into my head driving home, because im pretty close to zero on my stft, but i can still smell it running rich, what you guys think..
anywhere 'around' 0 for your fuel trims is fine, as long as you air/fuel gauge is bouncing around the ecu is doing its job on injecting the right amount of fuel. if your air/fuel gauge is going to rich during cruise then you need to lean it out.
i find mine pretty useful actually. Theyre not good for WOT tuning no, but theyre good to make sure the ecu is able to correct the amount of fuel as I just stated. Also, I know exactly how much throttle/what RPM range I should be in when the guage starts to go to rich, and if it goes to rich sooner than that, it helps me to diagnose a boost leak or something similar. The more gauges you have, the easier it is to diagnose a problem.
Nice answer, I use mine also in conjunction with my logger. It's just a quick reference to see if you are way too lean or way too rich. Rely on your logger and follow your timing.
  • Wanted 1g Chassis harnes fuse box
    • 92AWDHX40
  • Wanted 4G63 WTB Evo 560cc injectors or 450cc
    Im looking to pick up a set of evo 560cc injectors or possibly a set of 450cc injectors if the...
    • eclipsemf
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
