Tuning problem???, or????????
Spoolio
730
10
Sep 3, 2003
Port Charlotte, Florida
Sup, well here it is, my car was runnin good after i got it back from my mechanic , he retuned my safc and the car was pullin good through every gear, but my safc got reset and i put all the settings back to where he had them, but my car doesnt seem to be runnin right, even when he tuned it it was still blowing out some black smoke at high rpms, im runnin stock FP and stock injectors , i think i would be better off rippin the safc till i upgrade my fuel setup, as of now its not really doin much, plus i dont burn alot of gas either, i had my plugs gapped at .35 and i regapped them to .40, someone told me to do that cause i was pusing 16psi?, idk i may just go back to .35 cause thats how it ran better, but anyways tell me wutcha guys think i should do, heres exactly what my car is doing
backfires sometimes, black smoke at high rpms, when i take off in any gear from 3-5500rpms it will kinda like sputter and not have full power, its not smooth at all..
well this is how the guy had them
HiThrottle
(HI)
1500 - 10%
2500 - 11%
3500 - 12%
4500 - 14%
5500 - 15%
6500 - 16%
7500 - 18%
8500 - 20%
(Lo)
1500 - 8%
2500 - 9%
3500 - 10%
4500 - 11%
5500 - 12%
6500 - 14%
7500 - 16%
8500 - 18%
Throttle Point
Low Hi
65% 85%
NE Point
Ne1 1500
Ne2 2500
Ne3 3500
Ne4 4500
Ne5 5500
Ne6 6500
Ne7 7500
Ne8 8500
Dec Air
Thr 1.5%
Ne1. 9.5%
Ne2 8.5%
what do u think i should change that all to?, if u could just copy and paste a new set of numbers for me to try?, i know all applications are different but ive tried everything.
so ur saying just put every single one of those settings to 0? what about the NE Point stuff?, jus leave it as it is?
I agree with Canadian but you can also zero out the dec air. That is used for hotwire style maf cars and dont really apply to the karman style mas that the dsm is equipped with. Also, make sure you have the afc set properly. Mas should be set to karman, throttle set with arrow pointing up-right/ and cylinders set to 2.
