lilbayz311
- 101
- 1
- Feb 15, 2005
Ogden,
Utah
my car is finally all rebuilt but it has been throwing like 4 different codes. absolute manifold pressure, 02 sensor not detected, and multiple cylinder missfires. i got big cams so it idles rough sort of like a muscle car i have heard from multiple people. one problem is that i cant get it to idle any higher than it did stock. even adjusting the screw on the throttle body makes it higher for a min. but then it seems that the ecu overrides it no matter what and it goes right back down to jumping around between 700-900rpm which rumbles the whole car due to the size of the cams. NO im not downgrading my cams they are stage 3 crowers even though it doesnt say for use with turbo thats not the problem. i called crower and asked them what they thought about using these cams for my setup after telling them what all i had done and they asked ME how it ran. it pulls harder than i ever could imagine and easily spins the tires in second gear if i nail it too hard as long as im above 2000 rpm these cams are better than any turbo cam out there. i got advice from a local mechanic he asked me where my mass sensor had gone. i bought the car with cold air intake already installed and it had no mass sensor. this particular mechanic told me thats my problem and to get one "it will fix the majority of your problems he says" What do YOU think? it never turned on the check engine light before when i was n/t runnin it without the mass sensor. it runs well besides the idle and it occasionally dies when accelerating (no idea why?) but i promise its not from going lean. i have multiple ways of telling how rich/lean it is. we have pushed 16psi of boost already which was quite a rush. i plan on getting these problems worked out before i drive it much more. if anybody has any ideas please let me know
i cant wait to see how good it runs when its actually tuned right seems how it pulls so damn hard now. i cant wait to run the quarter mile. There is always going to be some bugs to work out on a newly built turbo conversion car ya know
