Trying to fix this oil leak need direction
arsgst
37
Mar 10, 2010
Tampa, Florida
Ok to recap I have a 95 gst with a 6 bolt swap. Guy I got it from said the timing belt was replaced and has a balance shaft delete. No timing cover on it now either. I have oil spraying everywhere on the drivers side and its coming from low on the motor. Im thinking Crank seal but could be wrong Ive never done this before. Well I got the crank pulley off now and need to know where to go now. How do I get to the crank seal? Can I start the car without the crank pulley on to see if I can get a better idea of where its coming from? Need as much help as I can get right now. Its my DD and its in my yard with no wheel or crank pulley LOL. I do have a crank seal oil pan gasket and a bunch of other gaskets already. If someone is real knowledgable and wants to give me a call please do (727) 637-2783 My name is Aaron Thanks in advance.
no this isnt what you really wanted to see for your first post, but how hard was it to get that crank pulley off?
5 min. Take the belts, pull the 4 bolts out of the center and either carefully pry on it with a scewdriver or hit it with a NON METAL hammer or mallet. You dont habe to remove the center crank bolt on the 4g63.
Nobody knows how I get to the crank seal?
