True 3in. Downpipe?
TROY
Sep 6, 2004
PLeasantville, Pennsylvania
Does anyone know where I can get a good deal on a true 3in. downpipe.
just FYI, the problem with a true 3" is it wont bolt up to your o2 housing, but if you have aftermarket, go for it, just thought id share that...mines custom and is 2.5" for about 4 inches, then goes to 3
I just put my Megan downpipe on last night and can not tell one bit of difference. Sound wise or performance wise. Might as well have kept my stock downpipe and highflow cat
Does the megan racing dp eliminate the cat ? , Because I want to be able to switch from a cat to a test pipe.
Is there anywhere that sells aftermarket O2 housings that will bolt up to a 3 in. downpipe?
That is because you are running your stock turbo I suppose. The T25 is so small that you probably can't tell a major change in power, spool, etc. If you had a larger turbo like a 16G or bigger, you would notice a difference then. :thumb: A bigger 02 housing would help a lot with that also.
Yes I am running a stock turbo. I've only had the car a couple of months and it's completely bone stock I've spent the last moth or so putting on new wheel bearings, ball joints, brakes, rotors, ect. ect. Basically rebuilding the whole suspension and drive train.
And now I want to start adding performance mods. I'm going to buy a megan racing 3 in. downpipe and I was told that it won't bolt up to my stock O2 housing. I was wondering if I can buy an aftermarket O2 housing that will bolt to my new downpipe.
IMO megan racing sucks. everything I have bought with their "brand" name has took a shit on me. I wouldn't pick one up. then again, it's just a pipe, right? :)
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
