Trouble with COP setup
ChrisMgst
83
Jan 3, 2012
Pasadena, Maryland
I purchased this COP setup on craigslist. It's a M&w pro 12 with a homemade COP setup. I m having a bit of trouble trying to figure out where the blue and green wire goes. FYI I am using a 6bolt bottom 7 bolt head and a 1g CAS with ECM Link V3, in a 97 GST.
view by clicking "View phots of this member's car"
http://www.dsmtuners.com/gallery/files/1/3/4/4/6/8/photo_thumb.jpg
Someone please help. the green and the blue find a home so I can get this car on the road!
If you look at the schematic for the m&w pro 12 the green and blue wire are coming out of pin 14 and 15 on the plug in my picture. The schematic says pin 14 is trigger A and pin 15 is trigger B. I need to know where to wire the blue and green wire in my picture. The triangle connector for the stock coil packs seems logical but I 'm a newb and need some concrete information.
What do you know about M&W Pro 12 CDI??
I have trigger (A) trigger (B) Tacho, and Ignition switch coming out this Pro 12 cdi plug.
I'm under the impression that I wire Trigger A to PT pin#2 input for cyclinder (2,3)?
Trigger B to PT pin# 7 input for cyclinder (1,4)?
Also can I wire Tacho, and Ignition Switch to the Power Transistor?
All four wires I'd like to run to the Power Transistor.
