Trapping 90MPH in the 1/8th...whats my 1/4??
highpsi93tsi
412
Sep 2, 2002
Last time out I trapped 90 in the 1/8th mile, just looking for ppl that did the same but what ET and MPH did you get in the 1/4 on the same pass?
Thanks
With a crappy 60" and low boost(3psi lower than I run on pump gas now), my car ran a 12.32 @115 with an 1/8 mph being 90.42. If you are awd, it should be between a 12.40-11.80, depending on 60' time and tune. 1/4 mph will vary with both also.
It was a 1.81 60 and a 9:20 ET. I find this quite odd as the car only had centerforce df clutch, .20 over stock engine, 2.5" exhaust and a plastic boost controller. Now it has real mbc and 2.5" I.C pipes. Theres now way this thing should go 12s like this, although it does pack a hell of a punch for what it is....
You'd be surprised what a 1g AWD can do with relatively few mods. What boost were you running on that run?
With a setup like that you're not going to gain as much on the last 1/8th. You probably won't trap as high as some of the people who posted in this thread.
X2 Good answer.
MB
I figure a LOW 13 next time out. Boost?? No clue. Not 20 or even 18psi..probably 15-16pounds. Its better set up now..I'll follow up
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
